04-15-2023 03:41 AM
I recently added on some data and it didn't work, I ended up adding it again and realize that I actually did pay twice. Am I out of luck or is there a way to get a credit back on my acct?
04-15-2023 01:18 PM
You could also just keep the doubled data. Do you see it say twice the amount of data?
04-15-2023 01:15 PM
Thank you! I will do that!
04-15-2023 05:31 AM - edited 04-15-2023 05:32 AM
@corrio Fiest, please confirm on both your credit card and My Account's Payment history that you did pay twice.
If you did, open ticket with PM support and they will likely be able to reverse one of the transactions
1. Please open ticket via Chatbot (requires access to My Account): click this Chatbot Ticket Link
Then click "Click here to submit a ticket ↗" to open the ticket submission page
Next, enter your Community login, then enter your question. Finally use My Account login or 4 digits PIN to validate.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
