Double charged
NKKI1976
Hello i hope all is well I was double charged! Said it didnt go thru then it did it again and changed my card twice.
2 REPLIES 2
slusagm
if you paid twice, the extra will be showing as a credit as Available Funds.  If it is there, it is better to leave it there for used towards next renewal
but if you don't see it anywhere, ask PM to check.  Oen ticket, then message PM using this link:
@NKKI1976
you can use the orange chat bubble bottom right of screen  or send  a  private message   To CS_Agent
