03-12-2023
01:50 PM
03-12-2023
03:12 PM
computergeek541
Wondering if I upgrade my plan to the $40 4G with 15gb data ------------------Would the un-used data roll over to the next month or would it be lost?
03-12-2023 02:56 PM
@Milk I notice that you've been a community member since 2018, so you probably are already aware that plan data never rolls over?
If you've never changed plans before and are wondering about gifted or purchased add-on data or mins, then no need to worry as plan changes doesn't affect those. The only one thing that might be affected is activation bonus data which probably doesn't apply here either.
03-12-2023 01:51 PM - edited 03-12-2023 01:52 PM
