11-23-2016 11:58 AM - edited 01-05-2022 12:51 AM
I want to abandon rogers and go to PM. However....knowing that I could have saved a bundle a few days ago....ouch!
11-23-2016 12:22 PM
Unfortunately, you wouldn't be able to get promo plan.. neither from Virgin or Fido, who had 4gb promo as well.
I would suggest you to get on month to month black friday plan from any provider (if there is, and there will be one likely) and jump to next promo.
11-23-2016 12:19 PM
How much data do you get on your current plan? As mentioned for the same price as the promo is now 6gb over 90 days. The flexibility of data plan is a huge perk as there are no overages and if you don't use it you won't lose it and at the end of your 90 days just stream or surf until the data stops. So if you can get by with the 6 over 90 days it is still a great price and you you wouldn't have to worry about missing future promo's becaue they have offered them to current members as well. Not just new activations
11-23-2016 12:13 PM - edited 11-23-2016 12:15 PM
If you are seriously considerng PM i would order a sim now and hold onto it untill you are ready.
you could use that sim and get the $40 provincial calling and 2 gb/moth plan (38 if autopay). and when there is another promo you can get it.
much depends on how much you are currently spending and what you are getting.
6gb /90 days is better than 2 gb month in my opinion
11-23-2016 12:02 PM
You can get 2GB for $50 with Koodo right now and they include 1000 minutes of free international LD. I realize it's half the data you want, but it's probably the closest deal.
11-23-2016 11:59 AM
sorry, from what I've heard the promo is over, unless you've ordred a SIM card BEFORE the promo end date
