04-12-2017 03:43 PM - edited 01-05-2022 01:57 AM
04-13-2017 12:35 PM
@TheOldVR wrote:
@will13am wrote:
@Samianauman wrote:
Thx guys
Add up already on kijiji selling it for sure going back to my android
Looks like found a solution for my post my own
Sell it lolI have a suggestion, throw it in the garbage. Please tell me which garbage can though.
LOL - ^^^^this... cause I need to buy one
I received no bravo for my suggestion. So I guess it won't happen.
04-13-2017 10:09 AM - edited 04-13-2017 10:09 AM
@will13am wrote:
@Samianauman wrote:
Thx guys
04-13-2017 01:34 AM
@Samianauman wrote:
Thx guys
Sell it lol
04-12-2017 05:44 PM
With an iPhone 7, it's impossible. Unless you JB- which you can't do on the 7 or 7+
04-12-2017 05:38 PM
04-12-2017 05:36 PM
That's why if you use True Caller with iPhones it has to create the giant "SPAM" contact to store all the blocked and known reported numbers. Apple doesn't give it the full access it needs to work as it would on an Android phone.
04-12-2017 04:59 PM
04-12-2017 04:48 PM - edited 04-12-2017 04:52 PM
@Samianauman wrote:
I know I m also android guy just trying for few days to see if I like it or not
Even if I hide original phone icon but when I get called original one still pop up lol
Phone app is the quite important in iOS, it is related to many system features.
For example, many app like Whatsapp/TrueCaller now relies on CallKit (should be part of Phone app). It is not that as simple as an app/UI. You can't just remove it and replace with something else.
04-12-2017 04:42 PM
04-12-2017 04:34 PM - edited 04-12-2017 04:35 PM
Nope, you are not allowed to.
You can hide the "Phone" app somewhere, and put the "True celler" app on the home menu bar.
I don't even think there is a jailbreak extension available for you to do that. Unless you write your own.
04-12-2017 04:34 PM
I believe if you JailBreak it you can change things up... otherwise it's the Apple dialer that you get!
04-12-2017 04:24 PM
Is that allowed? I thought for iOS, you always need permission from Apple before you can do anything. Bad joke, I am a fandroid.
