Does an iPhone 7 Plus (Model A1784 - using GSM technology) work on Public Mobile Network?
Denis_Nasciment
Gostaria de saber se a public mobile usa rede GSM ou CDMA. Alguém sabe?
A public mobile usa a rede da Telus e conheço pessoas que tem iPhone GSM e são clientes da Telus.
Thanks!
will13am
I just ran a check of this particular model of iPhone into the willmyphonework database and it checks out fine for use with Public Mobile service.  Supported LTE bands include bands 2, 4, 7, 17 and 40.  Of course 850 and 1900 Mhz on 3G are supported.
swiftypahk
 These are the bands that currently work with your iPhone 7 Plus A1784. Telus/Bell/PM supports a couple of these bands, and it also shows that on the apple website. https://www.apple.com/iphone/LTE/
Hope this helps
1 (2100 MHz)
2 (1900 MHz) 3 (1800 MHz) 4 (AWS) 5 (850 MHz) 7 (2600 MHz) 8 (900 MHz) 12 (700 MHz) 13 (700c MHz) 17 (700b MHz) 18 (800 MHz) 19 (800 MHz) 20 (800 DD) 25 (1900 MHz) 26 (800 MHz) 27 (800 MHz) 28 (700 APT MHz) 29 (700 de MHz) 30 (2300 MHz) 38 (TD 2600) 39 (TD 1900) 40 (TD 2300) 41 (TD 2500)
ShawnC13
@Denis_Nasciment, here is a link that has a good site for you to check network compatibility  https://productioncommunity.publicmobile.ca/t5/Getting-Started/Network-compatibility-and-APN-setting...
