12-01-2022 01:26 PM
When I signed up, we missed adding the discount plan code and only added the referral code. How can I go back and add this code to my plan so that I get the $20/mo discount? Also, the plan is no longer showing these savings on the website so how can I find this code to add it to my account?
12-01-2022 01:32 PM
You cannot go back to input code but you can ask agent to help you out.
To Contact CSA-agent; there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
12-01-2022 01:27 PM
@Guillentes if it is an honest mistake, it is possible that PM Support might be able to add it back for you
Please open ticket with PM Support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
