Disappearing posts
kb_mv
I saw a post complaining that their posts were disappearing. Before I could reply it of course disappeared so I'll post this and hopefully they will see it. I have had days (as many other regulars on here have had) where posts seem to disappear for no reason, or no understandable explanation never to be seen again. When it happened to me I eventually gave up and came back a day or so later and all was well. One thing that seemed to work was taking a screenshot of your post and then after it gets deleted, try again but only attach the screenshot.
If you are interested in knowing where your rejected posts go check here: https://productioncommunity.publicmobile.ca/t5/premod/moderationitemspage/tab/rejected
Moved:
Post removed due to profanity (as was that other thread that contained vulgar language). Swearing is not allowed here.
HI all,
just to add, if you repeat posting the same thing that got filtered, you have risking to have your community account banned from posting
This is something that happens regularly to me too.  The spam filter is set much too sensitive.  If something gets marked as spam, I would suggest moving on.  It really isn't worth the aggrevation to try multiple times to repost the message.
Sansan
Happens all the time and will continue to be so 🤔.
