Didn't use too much of my data but on self serve is show more each time I log in
ech_786
I am using wifi but each time I login to my self serve account it shows that I am consuming more and more data..
since this morning I have used 75 MB, I signed last night and 98 % of my time was on wifi.
Any thoughts?
PublicMobile101
I know on my iphone there is a setting that allows your phone to tap into data if your wifi signal isnt good enuf . that might be it
CaNuCk07
I think android has internal data tracking capabilities, im an apply guy, but i think android does.
THere are third party apps that work.  like my data manager is one.
AndreLaranjeiro
If you have an iPhone, ensure "wifi assist" is off.  That will automatically use data when your wifi is too slow. Here's a link on how to turn it off. Here are some other ways to reduce data usage.
ech_786
no I don't use any data tracking app ... is there one?  Should I be using ..
I am using LG G4
CaNuCk07
Do you use any data tracking app? What kind of phone do you have?
