04-25-2022
04:07 PM
04-26-2022
11:48 PM
computergeek541
Hi
my service seems to be stopped. I can’t call or text or get online.
can you tell me what’s going on?
04-26-2022
09:48 PM
04-26-2022
11:48 PM
computergeek541
@Lgillis wrote:Hi
@Lgillis - turn your phone off for a couple minutes. Then power it back on.
Also, try removing your SIM card then reinserting it, this helps to reset the sim if it shifted slightly and will also reping your network.
04-25-2022 07:12 PM
There might be a Telus outage in your area.
Check:
04-25-2022 05:15 PM
Was your renewal last night?
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #.
04-25-2022 04:15 PM
Try devicecheck.ca just in case.
What recording do you get when you dial 611?
04-25-2022 04:12 PM - edited 04-25-2022 04:12 PM
@Lgillis did you try to login to My Account and confirm if the account status is Active?
If it is Active, try your SIM on another phone if possible. If you have no other phone, try to reseat the SIM
If your account status is Suspended, it could be an Autopay failure. You will need to make a manual payment then. Go to Payment Tab, One time Payment and use the option "Other (Enter the desired payment amount)" and then manually enter the plan amount and submit the payment that way.
Let us know if you need any help.
