Default email address
10-18-2019 06:53 PM - edited 01-05-2022 07:38 AM
We have two plans on separate phones and separate email addresses.
When I go to login to check my useage, I am unable to open my account as the program defaults to my wife's plan and account. How do I open my account??
My Account
10-20-2019 01:16 AM
@Murphcrud1 wrote:We have two plans on separate phones and separate email addresses.
Clear cookies. Clear cache. Delete passwords. Reopen browser and try again.
10-18-2019 08:08 PM - edited 10-18-2019 08:10 PM
Which browser are you using?
I am using Chorme on Windows 10. I am able to login to 5 different PM accounts and I am able to switch between accounts without any issue.
1. logoff one user
2. select another email to login to another account.
3. repeat step 1 and 2 for all my accounts.
10-18-2019 06:57 PM - edited 10-18-2019 06:58 PM
Hi
Can you use another browser?
You can also try logging her out and then logging in with your email.
If it's still problem try removing her from saved passwords
10-18-2019 06:55 PM
@Murphcrud1 you should be able to login with your email address and your password
