01-24-2024 08:59 AM
Pls help me the deactivate the sim using the number because it was my used it and jow shes back to my country last sept and it keeps on charging my credit card.please please help me.
01-24-2024 09:06 AM - edited 01-24-2024 09:07 AM
to do that, log into self-serve if you have access and remove the subscription status from the subscription tab
otherwise, contact customer support as follows:
To contact a Customer Support Agent, send a private message to the Customer Support Agents by clicking here
You’ll need to be logged into your Community account for the link to work.
