09-08-2022 04:36 PM
09-09-2022 01:03 AM
open ticket with PM support and ask them to cover it
At https://publicmobile.ca/chatbot.
have trouble with Chatbot: Private message CS_Agent at:
Once ticket is submitted,(envelope icon on the top right) CS_Agent will reply you there.
09-08-2022 07:14 PM
In case your My Account is having refresh /cache issues, try calling 611 to obtain your data balance @jacquiefriesen .
If it doesn't match the 95% notification than you can likely ignore the text.
Try to install an app to track your ‘live’ usage so you can keep track. Public Mobile are 30 day plans (not monthly).
If you are android, try this one:
Data Witness app: https://play.google.com/store/apps/details?id=com.iwik.datawitnesspm&hl=en_CA&gl=US
I use this one myself and it gives me what I need from it.
You could also check out Data counter widget: https://play.google.com/store/apps/details?id=com.roysolberg.android.datacounter&hl=en_CA&gl=US
If you are an Apple user, I am sure there is a 30-day app that is available as well.
Managing Your Data Usage:
https://www.publicmobile.ca/en/bc/get-help/articles/managing-your-data-usage
09-08-2022 04:52 PM
@jacquiefriesen did you get a text about 95% used or yiubgit the number from My Account?
If you are on Android, the mobile data usage page can tell you which appbused the data. But make sure you change the cycle start date on that page to match your PM cycle start date
09-08-2022 04:39 PM
@jacquiefriesen hi you may have already used all your data what you see in your self serve may be a cached version of you data , clear your cache and cookies or try a different browser in secret or incognito mode , reboot your device and sign back into your account and see if it updates
