09-03-2022 03:18 AM
I purchased an add on data and need it applied to my account immediately can you help me?
09-03-2022 12:05 PM
@Barney_thecrow6 wrote:I purchased an add on data and need it applied to my account immediately can you help me?
@Barney_thecrow6 - is your public mobile plan current Active? Addons will only work on Active accounts. If suspended, you will need to make a payment to reactivate your plan.
If Active, what issue are you experiencing? If you see the data purchased in your payment history, then log out of your My Account, and try:
Does data work now?
If not, try your sim card into another compatible phone and see if data works.
And/or, check for outages in your area:
https://www.telus.com/en/on/outages
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
If still doesn't work, ask CSA to check if there is an issue.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
09-03-2022 04:01 AM
Are you on the $15 plan? Just login to your account and add the amount of funds needed for the add-on and make your purchase. Refresh your browser and reboot your phone.
It should be added right away.
09-03-2022 03:27 AM
and the Add-ons you purchased for U.S Roaming,then manually choose the network to T-Mobile.
09-03-2022 03:23 AM - edited 09-03-2022 03:23 AM
when you purchased any Add-ons will be in account immediately,
tried use browser from computer,and clear cache and cookies and use one page inPrivate mode,
or safari on private mode, To Login Page
and go to your Plan & Add-ons is will showing there.then just rebooting device should works.
