Data
Towlig
My data won't work got plan yesterday
15 REPLIES 15
Towlig
Got it guys thanks a million
Towlig
Ok thanks try that if that don't work giving up
Towlig
@Towlig as others have said you have wrong info in the APN.
Here's a screenshot.
If they don't work here's what's on my phone.
@Towlig wrote:
Without seeing the rest...APN should be sp.mb.com...not mp
Edit: yow...beat to it 🙂
@Towlig The APN shouldn't be set to sp.mp.com. It should be sp.mb.com
Towlig
@Towlig  please post a screenshot all your APN settings. Thanks!
Towlig
That didn't work
Triguy
@Towlig wrote:
Umidigi f2 I I just changed apn setting
Please restart your phone. Enable mobile data and try it again.
Towlig
@esjliv wrote:
Hi @Towlig,
Have you tried:
1- removing and reinserting you SIM
2-go into airplane mode for 10 minutes then back to normal, REBOOT
3-Since you are unable to use it, how is your phone set up?
Public Mobile APN - Also known as (Access Point Names) by going to
Settings>Wireless & Networks>Mobile Network> Access Point Names>New APN
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Here’s how to set up data in 3 steps for Apple:
1) Tap:
  • Settings
  • Cellular
  • Cellular Data Network
2) Input this info:
Here’s how to set up data in 3 steps for Android:
1) Tap:
  • Settings
  • More
  • Access Point Names
  • New APN Settings
2) Input this info:3) Leave all the other fields blank. Just hit save, and you’re good to go!
Hi @Towlig,
Have you tried:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Server: Leave blank
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
LovesToPM
Hi @Towlig
Which model phone are you using?
Do you have the correct APN settings?
