Data
06-24-2020 07:31 PM - edited 01-05-2022 11:50 AM
06-25-2020 06:02 PM
@gblackma wrote:@mdwallace97 text messages are sent out from PM 611 at 75 and 95% of your data usage. Stay safe.
This is true if you have no data add-ons on the account. If you have data add-ons, I have found no notifications are sent at all. I confirmed this in my last cycle by on-purpose using up every MB of my base data allotment.
I am not sure about if they still are sent at 75/95% of your TOTAL data allotment, but from what I've gathered from others, notifications may not be sent in that case either until all data add-ons are consumed.
With that in mind, pay regular attention to your data usage via self-serve (or 611).
06-24-2020 10:21 PM
Instead of eelying on a text Inwould.just go into your self serve account periodically, like every 5 or 7 days. Then if your data is runnning low then add on data for 15.00 for 1G. Or do the math to see if it makes more sense to move up to a higher plan.
06-24-2020 07:33 PM - edited 06-24-2020 07:34 PM
06-24-2020 07:33 PM - edited 06-24-2020 07:38 PM
@mdwallace97 wrote:Will public mobile notify you when your data is starting to run low?
Yes at 75% and 95% data usage levels by text message.
06-24-2020 07:32 PM - edited 06-24-2020 07:34 PM
@mdwallace97 , text notification is provided. I believe the notifications are at 75% and 90%.
