10-08-2019 07:15 PM - edited 01-05-2022 07:29 AM
10-09-2019 12:53 PM
@SD08 wrote:
@srlawren wrote:
@Luddite wrote:@dabr Different OP's in the two threads so shouldn't merge. In theory, each post related to @Nodata1's issue could be merged here 1 at a time. Seems merging has effectively been done with @Dunkman's summary.
@Luddite you can pick a paritcular reply in a thread (and all replies that link back to it) and move them to another thread.
I've moved all the related posts to this thread now.
@SD08 thanks!
10-09-2019 12:45 PM
@Nodata1 if it doesn't show any data there it means there's none left
10-09-2019 12:43 PM
Yes I have, but doesn't show in Self-Serve in Data and Adds-on area
10-08-2019 09:00 PM
10-08-2019 08:22 PM
10-08-2019 08:22 PM
10-08-2019 08:19 PM
10-08-2019 07:37 PM
@Dunkman wrote:From reviewing your previous thread, data not working on iphone 6 plus. Previously working. Already tried rebooting phone, removing SIM card.
More details may be helpful.
Did your plan just renew?
In your self service account, is the account status active?
Do you see the data counter in your overview page? Is it possilbe that you ran out of data?
Maybe try the lost/stolen phone trick. That seems to reset your phone/plan
To report your phone stolen. Login to your account. Choose Plans and Add-ons tab. Then choose Lost/Stolen Phone tab. The choose Suspend Service tab. Logout. Wait few minutes. Login in and report your phone found.
@Dunkman Maybe the threads need to be merged then? Perhaps @Luddite can assist in merging OP's threads.
10-08-2019 07:33 PM
@GR wrote:@Nodata1 did you check your account to make sure you still have data left?
@Nodata1 this is something you should definitely check. Most likely explanation.
10-08-2019 07:28 PM
10-08-2019 07:21 PM
@Nodata1 click on the ? Ask your data question and Simon the bot will help you.
10-08-2019 07:17 PM
@Nodata1 Yes what did you want to know about data?
10-08-2019 06:54 PM
@Nodata1 do you have access to another phone to try your sim card in it? Also did you check your account to make sure you still have data left?
10-08-2019 06:53 PM
iPhone 6 Plus. I don’t think my phone is the issue I have gotten data on it for the past 2 years or so with Public Mobile.
10-08-2019 06:48 PM
@Nodata1 what kind of phone?
10-08-2019 06:47 PM
Yes may times. Still not working. I also too out my SIM card and put it back in. Thought maybe that would reset everything? Didn’t work either!
10-08-2019 06:45 PM
@Nodata1 did you try restarting your phone and checking again?
10-08-2019 06:43 PM
When I dial 611 it gives me general options which don’t help with me getting my data to work!
10-08-2019 02:44 PM
10-08-2019 02:04 PM
Can't get data this month- no texting, no internet Autopay current and 0 Balance owing.
