Data
TheBlock
Why did it say that I was out of data when I never use it?
hi @TheBlock
voice calls work? text work and just not there?
who said you are out of data? you got it on the phone pop up? or text or from My Account? can you send us a screenshot so we can understand?
Yummy
If you keep your data on all the time some app or even phone might use it for all kind of updates and communication with the Internet.
Log in to your account and confirm how much data is really used by your phone.
@TheBlock
make sure your phone does not have data limiter enabled
Check My Account using Incognito mode to confirm
Try your sim card on another phone
