01-21-2025 02:02 PM
01-21-2025 04:49 PM - edited 01-21-2025 04:50 PM
Yes you can but depending how much data you need. Here are the number of points you need for the amount of data for 30 days.
Login to your account then to Rewards tab>Browse Catalogue.
01-21-2025 03:02 PM
Yes you can add data as an "add on" with your points. I typically use my points for a $15 bill credit as that gives me the most value, but if you need the data, that is another option, just keep in mind they will expire and wont stay on your account forever
01-21-2025 02:07 PM
@AlvisChimangwe You can buy a data add on with points, if that's what you mean. But bear in mind that data add ons expire after 30 days and don't roll over. Just go to My Rewards in your account and pick the add on that you want.
