Data
Miegh
I accidentally purchased 3 gb data for $30.   I meant to purchase 1 gb data for $15.   Is there a way to change this now?  Thank you
2 REPLIES 2
@Miegh  You have to submit ticket with support and see if there able to reverse it for you
private message   To CS_Agents click
@Miegh
PM is a prepaid provider and usually do not provide refund
however if it was an honest mistake and the addon was never used, Support might be able to help to reverse the transaction and let you rebuy.
Please message them:
