01-02-2024
03:41 AM
01-02-2024
08:07 AM
computergeek541
01-02-2024 06:51 AM
@Hollydan2009 You can also turn off individual apps' permission to use data so that they can't use data to update or for background tasks when you have data turned on away from home wifi. Also don't do speed tests when on data, they use a ton of data if you have a faster speed plan! When I had a limited data plan I just kept cellular data totally turned off except when I was away from home wifi. There is typically an easily accessible toggle for that on both iPhone and Android.
01-02-2024 05:05 AM
Check your phone settings for your data warning and limiter. The default is 5GB. Your phone may have stopped your mobile data. If you are connected to wifi it won't use your mobile data.
01-02-2024 03:54 AM
Data will stop working if it is used up on your alloted amount and you will need public wifi for your phone to connect to apps and websites.
If you set your phone on automatic connect to home wifi or public wifi. Your phone will automatically switch to wifi and will stop using your data. Some public wifi will need you to agree to their agreements and policy before you can connect.
What plan are you on? And what is the make and model of your phone so we can assist with your phone settings?
