Data usage
Pstone
I’m trying to keep track of my data usage (eg such as using google maps), how quickly is this updated in my self service account.
Pstone
Thank you for the google map tips!
geopublic
@Pstone  The data counter gets updated immediately. If you want to see how much data an app uses just go into your device's data usage system setting.
Jb456
@Pstone  to add.
In Google maps click your badge top right.
Then you'll see offline maps
In offline maps select your area then download it. Now you have the map so it does not need to use your data. You can download multiple maps.
Then go back to your badge top right then into settings and set it to wifi only.
Jb456
Sometimes within minutes sometimes it may take longer however my question is. Why are you using your data for Google maps?
You can open Google maps and then download "offline maps" of your area or province that will save to google maps
 Then set Google maps to wifi only.
You'll still be able to use Google maps with turn by turn directions with offline maps. The only thing you will not get is real time traffic which uses your data.
JoyLuck
Have a look at this thread. Debatable?
https://productioncommunity.publicmobile.ca/t5/Self-Serve/data-usage-update/td-p/476056/page/2
