Data usage
Tduggan
Let's say I buy the plan with 8 gigs. In my region that's 50.00. What happens if I get to 8 gigs is it automatically turned off? If not, is there a way to turn it off after the usage is done?
 @Darougar : Data just stops. No overages, no throttled unlimited here.
Darougar
What happens if you exceed your data limit?
If I  go over my allowance data on my mobile what should I accept?
Do I get more data automatically and be charged for it or what?
Triguy
Once you deplete your data it would stop.  You would either have to purchase more data with an add-on or wait until your next renewal date.
ChuckYeah
That's exactly how it works with PM. When the 8GB is up, your data stops. At that point you can purchase an add on, which are relatively expensive, choose another plan and activate it yourself, or you can send a ticket and the moderators can renew your plan early.
Or of course, you can just wait until your 30 day renewal, and get data back then.
No overages with PM!
