07-02-2019 02:39 PM - edited 01-05-2022 05:41 AM
So I could have sworn that when I started with PM, I could see my usage of data when I logined into the online account. I
logged in today and it’s dissapeared. My data is not working and I think it’s because I’ve used it all up but I can’t confirm? Is this just another quirk of PM? Or does it stop showing data usage when one hits their limit.
Joining Public
07-02-2019 05:26 PM
@Davt Normally the usage not on the overview under My Account means that they are used up. You can buy an add-on data or wait until next cycle. Maybe you need to rethink which plan may fit your needs before next cycle. Add on data is quite expensive.
07-02-2019 04:31 PM
I'm no programmer, but it seems simple to me.
If usage < max_usage
Print usage " / " max_usage
else
Print "You've used all your data."
Lol
All kidding aside, @srlawren makes a great point. Things that can never become questions leave more time for other issues. Especially when it comes to moderator time and wait.
07-02-2019 03:17 PM
@Davt wrote:So I could have sworn that when I started with PM, I could see my usage of data when I logined into the online account. I
@Davt this means you have used it all.
@Alan_K I'm tagging you yet again to remind you that having your data usage disappear form the Overview page is really, really confusing to your customers. Please please please have this changed. It's important. We should have ZERO of these threads in the community if the system worked as literally everyone expects it to, ie. if I've used all 4,096 of my 4,096 MB of data, I want to see "4,096 / 4,096 MB" until my plan renews.
07-02-2019 02:44 PM
Should be right on the main screen yes. Here's mine:
07-02-2019 02:44 PM
Any services that are counted show up on the overview page as long they are valid. If they are gone then either you don't have the service or it's no longer valid by way of being consumed.
07-02-2019 02:43 PM - edited 07-02-2019 02:45 PM
Hi @Davt , if the data usage disappears from your self-serve account, that means that you've used it all up for the cycle. And since Public Mobile is a prepaid service, you cannot go over your limit and there will be no overage charges. You can either purchase an Add-On data or you can wait for your next cycle to restart.
