Data usage problem !!!
Drav
I have a serious problem. My data shows I still have over 2gb left of data , but you sent me an email today saying 100%is all used up , now my data coverage doesn't work at all when away from wifi !!!! Very upset !!! Please correct this issue and allow me to use the  data I still have left ASAP !!!
13 REPLIES 13
gpixel
@Drav
you don't need incognito mode. press the refresh buttons
Drav
How ????? Not tech savvy and NO DIRECTIONS WERE EVER GIVEN TO BEGIN WITH AS A NEW CUSTOMER HOWE TO CHECK DATA , ITS LOOKS SIMPLE ON MY ACCOUNT USAGE BUT ITS NOT
Drav
How do I submit a ticket to a moderator please !!!! Frustrated customer
Drav
Please tell me HOW DO I DO THIS TASK INCOGNITO MODE ???? SOINNER ICON ???? EXPLAIN
Did you click on those little spinner refresh icons shown above?
You asked about seeing your data thinking you were out. What's this about a $40 plan?
Drav
HOW DO I submit a ticket to a moderator , I deserve and want my $40 promo plan please
Drav
How do I do that ?!!!! What is incognito mode ??????? Please explain asap
gpixel
the website doesn't automatically generate the correct usage. one needs to press the refresh buttons
Tapper22
I would  suggest to you to fill in a ticket ti address this situation. They are very helpful. As another member mentioned, this is a forum for discussion and sharing. Be patient and good luck.
@EJ
did you try to login with Incognito mode ?  Always use Incognito mode so you can see the correct usage and info.
EJ
I have same issue for my data!
DDM69
You are posting to a public forum made up of all customers. This is a place to ask questions, not to complain. Submit a ticket to a moderator if you are having issues.
JK8
@Drav
Log into self service but clear your browser cache first and then go incognito/private mode. Click on the spinner icon to refresh the self service page. You will then see the correct amount of data left/used.
