Data usage error
Massimo26
New activation was made on September 3rd for a 1gb data plan and right after,  activation, it shows 752mb used (71%)? When I click on data usage detail, nothing shows up.  I shouldn't have any data used, not so much seconds after activation of plan
2 REPLIES 2
hi @Massimo26
maybe just browser cache, please use Incognito/private/secret mode on your browser to login My Account to confirm again
If same,  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
Chalupa_Batman
Often the website and app have cache issues. Try clearing the cache on your browser, close browser, open and go into incognito mode and log back in. If your on the app, try swiping down as it may help refresh.
