Data stopped working
Araray
I am new to Public, signed up for $40 5G at 3G speed, 30 days in early July. Data worked fine up until 4.25G, then stopped working. I logged into my account and it says I have used 4250.8/5120MB. I'm on autopay and plan renews August 1st, but for now data doesn’t work. I have an iPhone 6S.
Any suggestions. Would be appreciated.
Araray
The 30 second restart worked!
Thanks for all the responses.
In this case, I hadn’t used up all the data (know that for sure only because it took me a few days to get around to the help community).
hycm53
Power off phone for 30 seconds or more then power on, hopefully will help.
ShawnC13
So data is still showing in the add-on section of your overview page in the self-serve?  I am not sure if data usage updates in real time or only a couple times a day.  Have you checked to see to make sure you haven't used up all your data and it just hadn't updated when you logged in and checked
XionBunny
There is also a chance you used it up and the website hasn't updated to reflect it, I'd suggest checking again in a few hours before trying troubleshooting or contacting moderators.
Triguy
Try the lost phone trick. To report your phone stolen.  Login to your account.  Choose  Plans and Add-ons tab. Then choose  Lost/Stolen Phone  tab.  The choose  Suspend Service  tab.  Logout.  Wait few minutes. Login in and report your phone found.  Reboot your phone.
If you still have problems then contact a moderator.
Moderator can be reached at
