Data stopped working suddenly (renewal date)
vlin
I noticed my data stopped working today and I haven’t made any changes to my plan. I noticed today is the renewal date so I wonder if that impacted it - I’m on auto subscribed in case that helps.
I’ve tried all the suggestions (eg turn off phone, reset etc)
thanks!
vlin
Thanks so much, will try that again!
@vlin
If you have a physical sim, test it with another phone
And submit a ticket with CS agent and ask them to re-provision your sim/account
open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗
    (if you cannot receive 2FA via SMS, click "Didn't Receive code" or "Resend Code" and choose "Send email" to get 2FA)
vlin
I see - I have an iPhone 14 Pro. Voice calls also do currently work. Tried resetting a few more times and restarting the phone but still not working 😕
@vlin what phone do you have?  Only Android phones have the data limit settings
Data limit on Samsung phone (would be similar on other Android phone), go to Settings > Connections > Data usage > Billing cycle and data warning.
vlin
Thanks @softech ! I reset my network settings and it still doesn’t work. How do I disable my mobile data limit?
@vlin
Voice calls work?
TryReset Network Settings
And make sure disable Mobile Data Limit
