06-06-2019 11:09 AM - edited 01-05-2022 05:15 AM
Hi, I activated my PM sim card two days ago. The network is working, I can call and recieve text messages. However, I am not able to use the data that should be available with my plan. I am thinking maybe this has to do with the settings on my phone. I have an Android (LG), I turned on the data but nothing happened. Could anyone help me troubleshooting this issue?
Thank you
06-06-2019 11:30 AM
If manually entering the APN info doesn't work, you might want to reset network settings: https://www.google.com/search?rlz=1C1GCEU_enCA844CA844&ei=VDH5XIztD-qe0gLgz5XQDw&q=reset+network+set...
06-06-2019 11:19 AM
@Geneviève wrote:Hi, I activated my PM sim card two days ago. The network is working, I can call and recieve text messages. However, I am not able to use the data that should be available with my plan. I am thinking maybe this has to do with the settings on my phone. I have an Android (LG), I turned on the data but nothing happened. Could anyone help me troubleshooting this issue?
Thank you
@Geneviève It has been reported here many times that when switching providers cetain LG phones need to have their network settings reset for data to work. Check your APN settings to make sure that they are correct.
These are the Public Mobile APN settings you need:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Don't forget to save these settings and then select this APN as the active one.
If you need to know where to find the settings:
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
I
