Data roaming
Agent99
I'm going to US  fron NB Canada to Bangor and onto North Conway NH for 3 days and going to get the data roaming. Can anyone tell me if it's decent. I need it for a program called circuit which optimizes your route and also uses GPS on your phone. Just wondering what their data roaming is like
2 REPLIES 2
hi @Agent99 it should be good, especially now yiu can choose both T-Mobile and AT&T
And if that does not work, submit ticket and agent will reverse the purchase.  So, give it a chance
@Agent99  should work good , just be sure to make sure you have data roaming turned on in phone settings and your connected to T mobile or AT&T and US roaming add ons start right away after purchased so just buy it before you go and it’s good for 15 days away
