Data problem
08-13-2021 04:12 PM - edited 01-06-2022 03:07 AM
I just got a new phone; Ulefone Note 11P. I checked my account, I have data. Phone works fine on wifi but not on data. Just says OFFLINE. Tried using the same APN settings as my old phone.
Thanks!
Phones
05-17-2022 12:35 PM
Problem resolved, it worked after I setup APN again
05-17-2022 12:14 PM
What did you finally do to resolve this issue? I am facing the same issue with the same phone now. Could you help? Network Reset and even factory reset didn't help.
08-14-2021 06:50 AM - edited 08-14-2021 06:53 AM
You may find this link helpful with your new phone...
https://www.hardreset.info/devices/ulefone/ulefone-note-11p/reset-network-settings/
and this....
Name
Mobile Internet
APN
sp.mb.com
Proxy
Not set
Port
Not set
Username
Not set
Password
Not set
Server
Not set
MMSC
http://aliasredirect/proxy/mb/mmsc
MMS proxy
mmscproxy.mobility.ca
MMS port
8799
MCC
302
MNC
220
Authentication type
Not set
APN type
default,mms,agps,supl,fota,hipri
APN protocol
IPv4
APN enable/disable
APN enabled
Bearer
Unspecified
MVNO type
GID
MVNO value
4D4F
08-13-2021 08:55 PM
It is enabled. I'll try the network thing, thanks!
08-13-2021 08:26 PM - edited 08-13-2021 08:58 PM
@deepg82 wrote:I just got a new phone; Ulefone Note 11P. I checked my account, I have data. Phone works fine on wifi but not on data. Just says OFFLINE. Tried using the same APN settings as my old phone.
Thanks!
This may be something you have done...but just checking - Is your Data option enabled?
If so, I would start with a Reset of your device's Network Settings.
Then see if Data works. If not check the APN settings, by methods already provided.
08-13-2021 04:16 PM
do one thing Make sure your phone is off before removing your SIM card,
and do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
- Open the Settings app on your Android.
- Scroll to and tap either "General management" or "System," depending on what device you have.
- Tap either "Reset" or "Reset options."
- Tap the words "Reset network settings."
or visit HERE
and go Changing APN Settings On Android device
click HERE
Ensure you have the correct APN settings by visiting HERE.
08-13-2021 04:15 PM
@deepg82 your phone should work on PM. It has all the required bands PM needs
what saying Offline? it shows Offline on top of the screen?
