03-07-2026
04:28 PM
03-07-2026
08:31 PM
computergeek541
When I buy an extra 5 Gb of data how can I make it so that the 5 Gb gets used first before my current amount
03-07-2026 05:06 PM
@Zayan23 It’s best to pick a plan that will suit your needs data wise and wait till you save 20 points to redeem $20 off your phone bill in my opinion as data add ons now expire after 30 days unlike before when it would just keep rolling over untill it was all used up like the long distance minutes add ons work
03-07-2026 04:42 PM
your regular plan data gets used first before add-on data.
