07-01-2021 06:46 PM - edited 01-06-2022 02:57 AM
07-02-2021 01:43 AM
@Paul46 another anecdote... Even when your data has been 100% used and stops working, you can continue to send/receive unlimited MMS/Picture messages. But the data setting has to remain on for it to work.
07-01-2021 06:59 PM
thank you for your reply
07-01-2021 06:48 PM
@Paul46 wrote:What happens if you use more than 100% of your data on your plan
Your data will stop working. There are no overages charges. To keep using your data, you need to buy a data add-on, ask a moderator to renew your plan early, or do an immedaite change to a different plan (but be careful as you can't get a plan back at a later time if it's no longer offered)
07-01-2021 06:46 PM - edited 07-01-2021 06:47 PM
@Paul46 : Without any data add-ons on hand...it stops...at 100%
