05-04-2017 07:27 PM - edited 01-04-2022 01:44 PM
Hello!
I've been with Public Mobile for a while and my data has always worked fine. However, I got a iPhone SE and plan that just started a few days ago with PM. I have changed the settings on the APN to sp.mb.com (I can only see APN settings for personal hotspot, not the other options).
When I turn on data, the LTE/3G symbol will show at the top but I will get a message saying "could not activate cellular data network" 😞 I do have a data plan so I don't understand the issue.
Please if anyone knows how to fix this, that would be amazing!
09-05-2020 06:54 PM
@ellenyw Thank you for sharing this solution! My data original worked when I set up my phone with Public Mobile but I never thoroughly tested it and my old apn profile must have overridden it. As soon as I deleted the old profile my data worked again!
12-02-2019 01:21 AM
Did you ever get your data to work?
10-10-2019 09:08 PM
Thanks, tried it and now data is working fine.
10-24-2018 03:43 PM
@cindyhoughton are you certain your plan includes data? Check in your self-serve portal, and ensure you have available data under the "My Data & Add-Ons" secton.
On your iPhone, make sure you're not using a configuration profile (often used in corporate environments, but it doesn't sound like your case... but just to make sure...): Settings --> Cellular --> Cellular Data Network --> Reset Settings. This will ensure the phone reverts to PM's settings.
Also, make sure you have the latest iOS (check in Settings --> General --> About). As of this writing, you should have iOS Version 12.0.1, and the Carrier profile should be Public Mobile 33.0. If either of these is not up-to-date, your best bet is to update them (Settings --> General --> Software Upate).
Help this helps!
10-24-2018 03:17 PM
i have a i phone 6 s plus i activated plan yesterday in the store i bought it in and the data plan does not work help
10-24-2018 03:14 PM
do you know what the anp should read
11-25-2017 03:27 AM
Hi @andrewface,
Try going to iphone settings >> general >> profiles and device management
and see if there is any APN profile there?
Also under mobile data, do you see "mobile data options" or "mobile data network"?
I think some companies may lock that but you can also change the APN info there?
11-24-2017 05:52 PM
I am experiencing this same issue but now with IOS11 there doesnt appear to be a profile option under general. I was on freedom so it makes sense that my phone may have had other APN settings. Is there another way to reset these?
09-16-2017 08:07 PM
I wonder if I'm having a data problem. I cannot download apps from the Google Play Store.
I'm trying to download the Ontario Lottery ticket checking app.. I've checked settings & re-booted but nothing works. Should I check the APN on the phone? Very confused & irritated by this.![]()
09-11-2017 06:15 AM
I moved to another network before a week. Then I have fetching problem on my iPhone cellular data (Mobile Data) not working. But I found a online guide about the cellular data not working and it worked for me. : https://www.howtoisolve.com/fix-iphone-cellular-data-not-working/
05-10-2017 03:41 PM
I just activated an iPhone SE coming from Telus and didn't need any APN changes. I also only see Personal Hotspot under Settings->Cellular->Cellular Data Network, but I left it at isp.mb.com and did not hit "Reset Settings". Works fine so far (youtube, google news working fine with wifi turned off).
05-04-2017 08:12 PM
Glad you solved it. typically the two most common data issues are
05-04-2017 07:50 PM
hm, I think I may have solved it!
There was another APN profile on my phone that was overpowering the normal settings I think. I'll just post here for anyone who has a similar issue:
Go to Settings --> General --> Profile
After deleting the old profile, data seems to be working!
