SIM card order
SuziieSuzy
Hi I'm sorry, I ordered the wrong SIM card size so how may I go and change my order?
DK
If you have a standard you can get it cut at most cell phone kiosks for a few dollars to free depending.
If you get the new tripunch sim as Chuk mentioned it won't matter as you just punch out the size you need.
Cheers
SuziieSuzy
No i haven't recived it yet. But i have a Moto G2 which uses a Micro SIM but i mistakenly ordered a Santard SIM 😕
chukdefatey
Did you already receive it? If so have a cut out buy adapter to make it fit. If you haven't yet received it then just wait you might get the new style tri-punch one.
