Data not working.
lmeldgard
Just returned from USA where I used a US sim. They had me download a file to get their  data working. Now I have put my public mobile sim in and data does not work. I have restarted the phone and changed the apn to SP.MB.COM and still no luck.
8 REPLIES 8
@dust2dust wrote:
This recent post of yours is incorrect. Your first post was correct. It's sp.mb.com.
Did you connect to wifi and go to settings general about to check for any updates like carrier profile?
@CountyDownIeUk? Registering the new-but-old number to Apple?
Adding - @softech - APN/username/password implies iphone.
If you switch SIMS in an iPhone. And then back to the original SIM the phone will ask you to confirm. I recently did this with some PM SIMS.  No settings to adjust. But if not same carrier SIMS.  Perhaps reset carrier settings and verify APN. And definitely reboot.
@dust2dust  , yes, given that OP keep just telling the APN and not the rest, I was suspecting, too
@lmeldgard  can you check your Carrier profile?  try to do an update with the Carrier Profile and see if it helps
Again, I suggest you to start with Reset All networks
@lmeldgard wrote:
Hi, I have changed the apn to sb.mb.com and restarted phone but do not have any of the other options. Only have user name and password which are both blank.
@lmeldgard
What brand and model is your phone?
usually use Reset All network is the quick and easy fix
If that does not work, you have to check more other APN entries.  Or send us screenshot of your current APN settings, the full list
lmeldgard
CountyDownIeUk
And reboot phone.
Meow
Since you used different SIM while in USA, did you try to reset network to default and then to try to adjust APN if needed?
@lmeldgard   you might want to do a Reset Network and see how it goes.  Please note after resetting your network, your saved Wifi will be gone as well and you will need to join the Wifi again
If it still does not work, please check your APN settings
Compare the APN settings below, try to update it and save:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
