02-03-2022 08:26 PM
Hi there,
I am wondering why I am having troubles with data. It is not working. I tried all methods such as, restarting phone, taking SIM out and putting it back in, resetting network settings. It's possible that I am updated to IOS 15.4, but why would software be an issue? Still no luck. Anyone got a solution?
02-03-2022 08:38 PM
When you go to setting, cellular, scroll down......are your switches on or off?
02-03-2022 08:38 PM
I will try downgrading for now. But its risky. I am not confident with how reliable downgrades are.
02-03-2022 08:35 PM
@rickersilken : This information might be useful. The thing we're looking to check and hopefully change is whether the phone settings can be changed from IPv6 to IPv4.
02-03-2022 08:35 PM
Thanks for sharing!
LOL nope. It shows its running data but I can't use the hotspot. It is "greyed" out.
02-03-2022 08:33 PM
This might be a dumb question but did you check if you enabled the Cellular Data?
Go to Settings>Cellular>enable Cellular Data.
02-03-2022 08:31 PM
Thanks for the input!
I will possibly downgrade but I am not sure if I want to risk it.
I have made sure no errors are being shown as as well as being out of data. I pay currently for 10gb
02-03-2022 08:31 PM
@rickersilken : This is a known problem. If you're in to some technical fiddling there _might_ be a workaround but we haven't proven it out yet. You could give it a go. But otherwise, the other method is to go back a version. You're on a beta. These are the risks with beta versions of any software.
02-03-2022 08:29 PM - edited 02-03-2022 08:29 PM
Log In Self-Serve, and check your history usage any left data,
maybe you use all data then is will be stop until next renewal cycle, or purchase Add-ons.
1. try to do reset your network settings,
2. try downgrade iOS some report has a issue with data.. How to uninstall iOS or iPadOS beta software - Apple Support
if needed get in touch with Customer Support Agent (publicmobile.ca)
if SIMon, can't submit a ticket send Private Messages to Customer Support Agent
