07-26-2021 09:35 PM - edited 01-06-2022 02:54 AM
I have data on my phone, but once I reached my limit of 1G, I started using the one time bonus 5G and my data is much slower than before. Why is this?
07-27-2021 02:46 PM
do one thing Make sure your phone is off before removing your SIM card,
and do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
and also you can clear cache and cookies for any Browser,
and just make sure your app Browser is up to date update check it
07-27-2021 02:09 PM
With data pages load fairly quickly, with the 5G bonus it takes a minute or two or the page doesn't open at all. I do not have that app I will try it!
07-27-2021 02:08 PM
I have not tried to reboot it, but I'll try to google something and it will take the page an extra minute or two to open or it won't open the page at all
07-26-2021 10:04 PM
@galdamezcelina7 wrote:I have data on my phone, but once I reached my limit of 1G, I started using the one time bonus 5G and my data is much slower than before. Why is this?
Add-on data and bonus data work at same speed as your plan. The rest depends on the network.
07-26-2021 10:01 PM
So, you have used up your 1GB monthly data and is now using the 5GB bonus? how slow it is? Did you try reboot the phone ?
07-26-2021 10:00 PM
Can you describe I'm more detail what is happening? As you know data speed is affected by internet speed. What is your typical download/upload speed? What speed are you getting now? Do you have the Speedtest app?
07-26-2021 10:00 PM - edited 07-26-2021 10:00 PM
Hello @galdamezcelina7 ,
Reboot your phone, or toggle into airplane mode than back into regular mode.
A reset of your network settings helps reset network issues as well.
