10-01-2025 08:33 AM
I activated my subscription plan yesterday and I called the porting line and they said everything is active and I did a reboot and everything but the data doesn't work. I got the 60gb plan but when I turn wifi off my
phone in my house it won't start using the data. Please help
10-01-2025 08:45 AM
It worked thank you!
10-01-2025 08:35 AM
hi @Molly05
what phone do you have?
make sure you removed all old sim card , or if eSIM, disable the old one
then Reboot phone and Reset network settings and test again
