Data not working….
tonyfreake
My data says 1.43G used of 31G but not working. Current subscription is 1G data so rest most be carry over. Can’t use data. Help
2 REPLIES 2
will13am
@tonyfreake , did you do a plan downgrade recently?  I am wondering if the remaining add-on data, particularly loyalty bonus data is current.  It would make no sense that your data would suddenly stop like this.  Try clearing app cache and rechecking the data remaining.
eddieO
hey @tonyfreake, can you check your phone settings to see if you have a data limit set that is restricting more data to be used, this could be your issue
