Data not working
KirS
Hello I ran out of data so I added more data but it still didn’t work. So I tried again. Now I’ve charged twice for extra adding and it’s not working. Please remove charges
2 REPLIES 2
dust2dust
If you're on an Android then check to see if you have a data limiter set. And maybe you didn't even run out of plan data? Did you get warning texts at 75% and 95% from here?
@KirS Reboot the phone and see if it works . Then check here like this for your data add on and if you have the extra charge sitting in available funds .
Try again incognito/private mode
And or lap top /computer
                    OR
simply try refreshing the page to check data plan / mins / add ons
if something is still wrong please submit ticket to support to fix
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
