Data not working, tried everything!
Moop
I ported my number from koodo and activated my account last night, I have an LG g3 phone. Calls and texts are working, but data is completely not working - when I select the option to turn it on, the data icon doesn't even show up at the top of the screen. When I check my self serve account, it shows that I have used 0 of my 12 gigs of data. Same with my data usage tracker in my phone.
I have already tried following the default knowledge base article, and I have also tried numerous other fixes relating to the APN settings on this forum, but they do not work even after restarting my phone. I have currently reverted my APN settings back to the ones listed in the knowledge base article.
What else can I do? Thanks in advance
11 REPLIES 11
CS_Agent
Customer Support Agent
Hi @mntbykr,
We've replied to your message! Please check your inbox.
Cheers,
Syed
srlawren
@mntbykr sorry I misunderstood your problem: did you recently port in a number?  I think you did, and it failed.  This is consistent with you seeing your texts with your old SIM (I'm assuming from your previous provider).  You need to contact the moderator team to help with your port.  Please see this knowledge base article for details: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-to-Get-Help/ta-p/251745
In your message please include:
  • PM Phone Number, 4 digit PIN, Account email address, Detailed explanation of your issue
If you have a Porting issue, please also include:
  • The number you want to port, PM sim number, old account number, old account name exacly as on bill
Don't know your pin?--provide any 3 of the following:
  • Complete mailing address, Email address, Alternate phone number, Date of birth, Last top up date & amount
mntbykr
I also popped in the old sim card and voila, all my texts come through.
mntbykr
I just tried the lost phone trick, still nothing.
@mntbykr
Maybe try the lost/stolen phone trick.  Report your phone lost/stolen in self service account.  Logout.  Wait few minutes.  Login.  Report your phone found.  Re-boot your phone.  This might reset/re-start your SIM card.
If you have another phone, try putting your PM sim card in the other phone.  To help distinguish between hardward versus mobile service issue.
If none of the above works, you may need to contact moderator, but expect 2-3 day wait.....
Send a private message to moderator through the following link :
Please include in the private message your phone number, your account number and PIN code.
At least you have data.  You can try a service like fongo.com for now to make some calls, etc.
mntbykr
My data is fine now after a factory reset. Now I am not receiving calls or texts. I am not yet excited about changing to PM.It is just one problem after another.
popping
@mntbykr, @Moop,
If you have a LG smart phone, you need to do a network reset after provider change.  If network reset does not fix your data issue, do a factory reset.
Network reset changes only network related parameters - nothing else.
Factory reset deletes everything.  You need to setup your phone again if you don't have a backup.
Always do the network reset first before factory reset.  But backup your data first.
mntbykr
I need the same problem corrected! It is frustrating that there is no customer support!
srlawren
Hi @Moop.  Others have had some trouble getting data working on the G3 in the past.  I believe the only thing that ends up resolving it is a factory reset.  Unfortunately, this will wipe all your data from the phone, so be sure to back up anything important (photos, documents, texts) that are not synced to the cloud (contacts?--most people sync to Gmail but just in case you don't) before you do it.
This isn't limited to Public Mobile, I seem to recall it affecting changing carriers on the G3 in general.
Pier
@Moop
How do I set up data/APN on my smartphone? [ Edited ]
Options
‎12-23-2014 11:47 AM - last edited on ‎07-16-2015 02:46 PM by Mansi_G Retraité / Retired
In this page, you will find Public Mobile APN Settings for your smartphone.
Step by Step APN configuration
Step1:
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Blackberry
OS 10 - Settings > Network and Connections > Mobile Network > Tap the settings icon (dented wheel)
Windows
Windows 8 Step 1 Settings > cellular > Add or Edit internet APN
iPhone
Click here
Step 2:
You will need to input the following information:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
Step 3:
Select Save/Done. Select Public Mobile to connect to the Public Mobile network
Pier
Hi @Moop
@welcome to the community as well as to PM. Just check to set up your APN. You can delete any existed profile on your phone and set up the PM APN.
