4 hours ago
Anyone have issues activating the data on a new ESim? Call & texts work, but not the data.
4 hours ago
hi @TJNorrish
fisrt, make sure your old physical sim card is removed , or if it the old carrier sim is esim, disable it from Sim Manager or Settings->Cellular
On the same Sim card Manager, or Settings->Cellular screen, check if Public Mobile esim is there. If it is , make sure it is set as Primary and enabled (or Turn on this line is enabled), then Reset Network settings
if that does not help, ask support agent to check, submit ticket by direct message:
4 hours ago
situation like this is your old sim still there. Remove the old sim card and disable old esim. Check and enable PM sim card and set it with label Primary. Then Reboot phone and Reset network settings
