Data limit
vanhtran
Can I use more than the mobile data limit of my plan and will be charged for the exceeded amount in the following month?
@vanhtran
for more information about Managing Your Data Usage visit  Here link to save your data....
Triguy
Once you reach your limit then it will stop.  You can supplement your plan data with an an add-on $15 for 1 GB.  Once you plan data is consumed then the add-on would be used.  The add-on data remains in your account until it is used up.
t_p
PM plans are prepaid, so when your minutes/data are used up, service will stop.
You'll have to buy add-ons or renew your plan early depending on your needs.
Unlike minutes/data allotted in your plan, add-ons don't expire at the end of 30days cycle and will roll over until used up.
hairbag1
@vanhtran...nope. Once you reach your data limit, your data will just stop until next renewal OR you buy an (expensive) data add-on.
As previous suggested...there are no extra charges.
edit....
In Canada Data Add-Ons
1 GB Data...$15
200 MB Data...$5
@vanhtran
when your data limit used, is will off until next renewal cycle
at public mobile Prepaid Service No fees extra charges,
