Data in the US
Big_ma413
For that promo 20 gb for 34 plan. Fine print says you can use data in the US. Can anyone confirm?
2 REPLIES 2
dust2dust
That plan is not the roaming plan. The fine print is a list of endnotes (footnotes) with those symbols that are referenced in the plan area or elsewhere. They're not fine print for everything.
@Big_ma413 $34 is a Canada only plan.
The line just means you can buy US roaming add-on to use the service in US
Add: **the fine prints there is a general find prints used for all plan
