Data for the internet isn’t working
Verminator
Signed up 2 days ago, 10G plan, eSIM, transported number over just fine. Texting and calling works, but the internet/apps barely work if ever. What am I doing wrong?
2 REPLIES 2
Verminator
Tried all of the above over the past few days. Went into the Telus store today. The fix was that I had to delete the VPN in my iPhone settings. Then I logged into my Nord VPN app again and it all works great now.  The VPN essentially just needs a re-set.
hi @Verminator
what phone do you have?
make sure your old sim card is removed , if eSIM, please doable it
Then try Reset Network Settings and it should work
