08-02-2026 10:08 AM
I’m on a plan where I get 1GB a month and my subscription says that exactly. When I look at the other monthly plans they indicate 35GB. Is that per month or for the year? They don’t say per month so I’m confused
08-02-2026 11:23 AM
Thank you all. Because it didn't specify per 30 days I thought maybe there was some loopholes. I didn't want to change my plan if it was per year. I don't use a whole lot of data but do need more. Thanks again!
08-02-2026 10:42 AM
Higher Data plans are your allowance per 30 days! But you cannot carryover data into next billing period. Use it or lose it.
08-02-2026 10:36 AM
FYI, if you do upgrade your plan, just a warning: you will be unable to downgrade later (or very difficult to downgrade).
Public mobile offers personalize plan offers for existing customers. The plans offered are usually more expensive than your present plan. So, if you upgrade, you unlikely will be able to switch back to 1GB plan.
08-02-2026 10:17 AM
hi @Jan8888
1GB is per month, technically every 30 days.
yes, some plans have more data, like 35GB /30 days. These days, many need lots of data, so 30GB or 50GB are not unusual. PM even has 200GB or 250GB per 30 days
just an FYI, PM only offers plans per 30 days and no annual plan
08-02-2026 10:16 AM
Yes, that is 35 GB per month. (30 day cycle).
