Data doesnt work
vincent568
I just got a new phone because I broke my previous one and I am not sure why my data on my plan is not working for me (The phone is a umidigi A9).
9 REPLIES 9
BlueB
Glad it was a relatively quick and easy fix!  Enjoy your new phone!  🙂
vincent568
After completing the apn settings my data now works thanks for the help.
@vincent568- As per the PM compatibility checker, that particular model is not listed as compatible.  Doesn't mean it is not compatible, but it does not show up on the list.  A couple of other A#pro models are listed though, so it might be compatible.  You should check the frequencies/bands used by your model (A9), to see if they are compatible.
@vincent568  can you update the APN setting?  Other people have complain that they can't update the APN setting on Umidigi phones, they have to use some workaround.  Let us know if you can edit the APN
vincent568
yes i still have data and my apps still funtion over wifi just when i do not have a wifi connection im still unable to use data. My month just reset 3 days ago and i still have 90% of my data available.
it's likely an APN setting issue.
What is the APN setting now?
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Hello @vincent568
Ensure data is enabled.
With the Public Mobile SIM card in the phone, do a RESET of your Network Settings.
Check your APN Settings:
BlueB
@vincent568
Welcome to the Public Mobile community!  🙂
A couple things to check:
  1. When you log into My Account - does it show you still have data available/remaining to use?
  2. Do apps work okay when connected to wifi?
If your phone apps work okay with wifi, I would double check that the APN settings are correct - if you make any modifications, be sure to reboot your phone afterwards just in case!
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Server: Leave blank
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
You can also try troubleshooting by placing your SIM card in another phone to see whether data works.
Note that your phone may track the "wrong" data usage by month when Public Mobile's cycle is actually every 30 days.  This can throw you off and give you the wrong impression of how much data you actually have used/remaining.
and do rebooting your phone - This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
How to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  HERE
Changing APN Settings On Android device
click HERE
