05-09-2023 06:35 PM
05-11-2023 02:56 PM - edited 05-11-2023 02:57 PM
@dahliacassel did you just join PM? Was the data ever work on this phone with the PM network?
If data is an issue, usually it is the APN
Check the VPN section on the phone and delete all VPN profile
Check if it works
If still does not work, please check your APN settings, compare it with below and try to update it and save:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include dun for hotspot)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
05-11-2023 02:53 PM
Android OnePlus 6T and all my data is still available
05-11-2023 02:53 PM
OnePlus 6T
05-11-2023 02:52 PM
I checked and I haven't used any data. It's all still remaining
05-11-2023 02:51 PM
Did this. Still not working. I can run speed test over wifi and it works but when I disable WiFi and use either automatic network selection and manually choosing public 3g it does nothing
05-09-2023 08:55 PM
Try resetting the network setting on your phone but you need to re-enter the password for your home WiFi.
This happened to me once.
05-09-2023 07:01 PM
log in on your laptop, then look for that little spinner thing...
If you've used up your data, it's done until next regular renewal OR you purchase a data add-on.
Let us know if you still show data available for further direction.
05-09-2023 06:48 PM
Which phone do you have?
05-09-2023 06:38 PM
Android or iphone? If you click on any little spinner refresh icons lower down, do you see that you have data available?
