10-25-2018 09:09 AM - edited 01-05-2022 02:17 AM
Hello I have an LG X Power 2. I've been with Public since about February I'd say, I have had the same plan ever since. 60$ for 5gb of LTE/4G data and provincial texting/calling. I had an Essential Phone PH-1 but it broke and I had to switch to this phone in the meantime. The sim card I had in my Essential was also damaged so I switched Sim cards online. Ever since I switched my Sim card I haven't been able to connect to my data service or receive or make any calls. My plan is active, my data is on, it doesn't work in other phones either. I have checked the APN settings and I'm positive they're correct, maybe if they have changed slightly and someone can post them here to be sure that would be greatly appreciated.
Thanks.
10-25-2018 09:48 AM
Here is the settings for your phone for APN:
https://apn-canada.gishan.net/en/apn/public-mobile/lg-x-power
But as stated above, if the SIM does not work in other phones, it is likely an issue with the SIM/service. If the SIM card number is correct, trying the lost/stolen phone trick might work. In your self service account, choose the lost/stolen phone option. Logout. Wait a few minutes, Log back in and choose found phone. This resets the SIM and helps restart plan. Does not work for every situation.
If that does not work, you might need to contact moderator, but wait times are 72+ hours.
Send a private message to moderator through the following link :
Please include in the private message your phone number, your account number and PIN code.
10-25-2018 09:39 AM
@kchisholm93 wrote:Hello I have an LG X Power 2. I've been with Public since about February I'd say, I have had the same plan ever since. 60$ for 5gb of LTE/4G data and provincial texting/calling. I had an Essential Phone PH-1 but it broke and I had to switch to this phone in the meantime. The sim card I had in my Essential was also damaged so I switched Sim cards online. Ever since I switched my Sim card I haven't been able to connect to my data service or receive or make any calls. My plan is active, my data is on, it doesn't work in other phones either. I have checked the APN settings and I'm positive they're correct, maybe if they have changed slightly and someone can post them here to be sure that would be greatly appreciated.
Thanks.
What provider did you use this phone on before? If it is a new phone to you I would do a factory re-set anyway to clear it. As stated below are you sure the SIM number matches what you changed it to because if this new SIM isn't working in other phones I would think it was a SIM issue and not a phone issue
10-25-2018 09:22 AM - edited 10-25-2018 09:27 AM
I would check that the last digits on the sim match what it says I self serve (make sure sim change happened)
Try the lost stolen feature trick, seems good at resetting some phone issues.
Edit
Does texting work?
If it was just no data I would suggest a network setting reset, most lgs rrewure that or a factory reset to get data working.
Mindyou you said it didn't work in other phones... So I'm back to my first thoughts.
